Hi All,
I was running a mixer wagon on my John Deere 2130 the other day and the pto randomly stopped turning and made a grinding noise like gears not fully engaged. I immediately disengaged the pto and the grinding stopped. When i tried re engaging it made the grinding noise again under load. Once the mixer wagon was unhooked I found pto engaged no problem when no load on the system. Could this be happening due to loss of hydraulic pressure which is needed to engage the pto? failing pto clutch?
The plot thickened today when I decided to service the whole rear end, clean screen, change filter, fresh oil etc. When I pulled the front drain plug (in the same region as the oil filter below drivers right heel) a bunch of pieces of bearing needles and one random rivet came out with the oil. Yikes! Is there a likely culprit for this bearing material to have come from? And I assume the rivet came from a clutch or brake disc? The hi lo seems to work fine as does the main clutch. Only issue I was aware of before this was that the pto brake didnt work so it turned all the time. Any ideas? Whats my next step to address this ?
I assume the source of the problem is in the front half of the rear end as thats where I found the shrapnel. The rear drain plug was clean.
Thanks!
Thanks!
