I have a new 520 that had been setting in shed for years. and the wiring was getting tired. in replacing it I found brown wire extra from switch. found wiring diagram and it showed wire going to point side of coil (+) terminal. So with all that said, why would a wire from switch go to positive/point side of coil? and also tractor runs. Just don't like to make short cuts in history's great engineers designs. if that makes since. If the wire would have went to neg side of coil I would guessed it might be working as a resistor bypass to keep voltage up with lights in the on position. any thoughts would be helpful. Thank you.
