GPinMT
Restored a Frazer B1 6 rototiller and it won't start. Fresh overhaul but no vacuum. Could new crank seals be in backwards?
The old Frazer rototillers were a 2 cycle, at least those that I have seen and by your question about the crankshaft seals makes me believe yours is a 2 cycle as well. Yes, if they're in backward it absolutely create a vacuum leak. Does the engine try to start if you squirt a little gas thru the carburetor?
Yes its a 2 stroke. Will pretty much fire only a few times. Blew in the air cleaner hose while attempting to start it. Got it to run at least a few revolutions. Haven't tried a compression test but seems good putting my finger over the spark plug hole.
I am no guru of them things (been around them some) but on the two cycle part. Chainsaw, snowmobile etc. look up a pressure test of the crankcase. There are several ways to do it and it will pinpoint any leaks.
Spark plug in, carb wide open it pulls about 3 in vacuum measured with a vacuum gage in the lower crankcase plug. Hand over carb intake its about 4 in. Compression is 50 lbs pulling the starter. Pulling the starter the vacuum jumps erratically from 3 in vacuum to about 3 lbs pressure. Acting like a 2 stroke with broken reed valves!
Found the impulse for the magneto appears to be in the wrong clock position. The impulse arm stop was at 10:00 and appears it needs to be at 2:00 for consistent operation. Will find out tomorrow.
