Leonard Mo Molberg
I have two old MH55D tractors - one of which is still being occasionally used. The other one is a parts tractor because the block is completely cracked and shot. Both have Bosch fuel injection pumps.
At one time it was my primary farming tractor for about 80 dryland acres.
I have no idea of what year they were built - I would guess somewhere between 1946 and 1955?
Can anyone help me on what I need or where to get the proper fuel filters for this tractor? Any help would be greatly appreciated.
The running one quit the other day, starved for fuel, and it appeared that the primary filter would not pass any fuel. Imagine my surprise when I took off the bowl and there was NO ELEMENT inside, and it was all full of "gunk". As I was roading it at the time, I cleaned it up as best as possible, then blew back through the lines into the tank with a little bit of compressed air I had in a portable tank. Then I was able to pump the fuel into the secondary filter and through the bleeder plug and restart the tractor to get it home.
I have, however, no idea of what filter element should go in there. It appears to only be about an inch and a half in diameter and maybe only two to two and a half inches long, and is held in by a cup shaped flanged knurled nut on a long threaded rod, which also holds the bowl on at the bottom.
The secondary (final) fuel filter appears to be a sealed can which has threaded fittings top and bottom and a bleed screw at the top. It is held near the injection pump with a bracket, definitely it is not a "spin on" filter!
NAPA auto parts here seems to be good at finding obscure items, but they did not have anything listed for the Massey Harris 55 Diesel, and another listing we thought might be good was of no help, the filters being entirely different.
Though they are only about 30 serial numbers apart, the two tractors are quite differently equipped. The one not running has a place on the front of the engine block for a gear driven hydraulic pump (which is missing, unfortunately) and the other one has no provision for one. One has 18.4 (15) x 34 tires, the other running one has 23.1 x 26 (if I remember correctly. There was a Massey dealer in a town near here some years ago and they had a brand new hydraulic pump on the shelf to fit the parts tractor (which was running well at the time) but they wanted something over 800 bucks (20 years go?) for it and though I'm sure it eventually went into a dumpster, they would not consider dropping the price one bit. It was twice as much as I paid for the tractor! I added a 12 volt hydraulic lift-gate type pump to the tractor to lift an implement with a single acting cylinder.
Also, does anyone have any records of the stated or tested horsepower for these tractors?
Thank you all for bearing with me on this.
Leonard
Leonard
