Mf1020prblmchild
I have a Massey Ferguson 1020, 4x4, standard, MF Loader. So I scored this tractor for free in non running condition. Has not run in at least 10 years. Was parked because of bad hydraulic pump. Got it running after going through it, tearing apart injection pump, diagnosing and fixing clogged cooling system, new starter, used hydraulic pump, filters and fluids.
Now that it starts consistently trying to figure out hydraulic problems. Loader hoses are bad. Disconnected and capped at supply and return on relief valve. Pump is moving fluid on high and low pressure side to relief valve. Pulled relief valve and inspected. Still no three point pto engaged or not.
Thinking piston might be stuck in three point assembly. Help. What should I check? Do accessory outlet hoses need to be looped not capped for three point function?
Appreciate any advice.
Ryan
Ryan
