Diymechanicmike
Hello I have a mf3165 diesel that has been smoking out the exhaust and breather tube. Initially I thought it was the fuel in it was bad or something cuz it has lots of floating gunk in the fuel bowl and the tank was full of orange sludge. Got that all cleaned up and new fuel in it and a new fuel filter/glass bowl. BTW the engine started up great like there were no issues at all except the smoke. Also the previous owner put a brand new injection pump on it which I thought was dump with all the gunk inside the fuel but whatever I cleaned it out. After all that it still smokes out the exhaust so I went further and went to change the oil in it and when I drained it, it was old black and slightly milky. I left the drain plug out and had a bucket under there to catch the rest of drips while I dumped the oil into an old jug. Went and ate lunch and came back out to put plug back in and noticed a bright green drip of anti freeze on top of the drips of oil in bucket. So I have a very small coolant leak getting into my crankcase somewhere causing the smoking issue. I'm thinking either the head gasket or possibly water pump but not sure if it can leak back into the crank case or not. But I do know I'm not getting oil into my coolant sector because the coolant is bright green and brand new looking.
So my question is where should I begin my next investigation or possible repair job?
Is there anyway for coolant to get into crankcase without oil getting back into the coolant?
Also is there anything easy it could be before I tear the head off to see if the headgasket is blown somewhere or just weeping?
Thanks,
Mike
Thanks,
Mike
