MF in Canada
Hi folks,
It's good and stuck. How do I pull the front axle pivot pin on my MF245?
As noted in an earlier thread, the rear bushing dropped out. I've got the tractor apart to some degree and I've pulled the stay pin which holds the pivot pin in place. That stay pin was pretty well stuck in there, but it did come out.
I can see that the pivot pin is stuck within the axle. It turns freely in the remaining bushing.
I have tugged on it and banged on it fairly smartly. It does not budge. Based on the way the stay pin was stuck in there, I am guessing there was no anti-seize applied when this pivot pin was installed. It's stuck to the axle, quite securely.
My only thought is to build a puller and to apply an unrelenting force with that... but I don't want to break the casting.
Any experience? Thoughts?
Thanks,
Eric
Thanks,
Eric
