Hi. I have a Roosa Master fuel filter assembly on my 4140 Diesel that is/was leaking at one of the gasket seals (there is one on each end of the filter element). I bought a new filter marketed under the CarQuest brand at a local auto parts store. It was supposed to be a direct replacement for the New Holland element I removed (part #86546599). The gaskets that came with CarQuest filter are all slightly oversized, so that when I try to tighten the cap down "hand tight" as the embossed lettering instructs, the gasket slides out of position, and no seal is created. The old gaskets were not exactly the right size, either, and were not reusable.
Two questions: 1) If I buy a genuine New Holland filter online, will the gasket size issue be eliminated? 2) Is there any kind of conversion kit made/marketed that will allow me to replace not only the filter element, but the surrounding parts, so the new assembly is less likely to leak?
