The power steering return line on my 4630 started to leak because the hose was starting to deteriorate. This is the top line on power steering valve in the cab console and has hose clamps on both ends. I got the replacement hose from JD and put it on, but it has now blown off of the steering valve fitting twice in just a matter of a few minutes. I have torqued the hose clap for all it is worth, but it still blows off. The hose has a hard red plastic liner in it, sort of like PEX, and I'm wondering if it was meant for use on a barb fitting rather than the one on the steering which just has kind of a fat spot in the tube.
So if I need to go to a different hose, what would be recommended? It is 3/8" inside diameter and 5/8" outside diameter and can't be too much bigger on the outside as it needs to fit through a hole in the firewall.
