I have a question I'm hoping someone can assist with. Just how hard is it to time a later side mount distributor engine that has had it's original cracked block replaced with an earlier front mounted distributor block? As you can see in these two images, this 8n has a side mount distributor but there is no timing hole on the flywheel cover. Another issue is that the oil filler tube is in the earlier location and has been modified to clear the alternator/generator location of a later style 8n. I was seriously considering buying this tractor but didn't realize the block wasn't actually correct at the time I was looking at it. The current owner had a shop do the block replacement and I'm not exactly sure they even realized the difference themselves. Would this be considered a deal breaker that I should walk away from or just a minor issue that can be worked around? Does anyone see anything else wrong with this setup that I'm missing?
Thanks, any input would be greatly appreciated.
