Al/ lindley
After rebuilding my 8n with a side,ount distributor, i am unsure of how to set the timing. My sherman transmission has no inspection hole to view the numbers on the flywheel. So I put the engine on top dead center using a dial indicator with both valves closed and marked the front pulley to show where TDC is.
I think its crazy that I can't see the marks on the flywheel. I'm hoping this thing will run. I'm just going to put the distributor back in the block and point it toward number one spark plug and hope it runs
