Remote hydraulics
ZacMF165
I'm looking to install remote hydraulics on my MF 165 so that I can run a front end loader. I've added a picture of what I've found my only thing is does anybody know if they make a valve like this one but with out the controls on the valve it self. So I can use the controls that are mounted on the front end loader.
https://www.ebay.com/itm/394418823180?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1H0V5ombqSUmj9oFdixdtFw43&norover=1&mkevt=1&mkrid=711-117182-37290-
0&mkcid=2&mkscid=101&itemid=394418823180&targetid=1585159291611&device=c&mktype=pla_with_promotion&googleloc=9014290&poi=&campaignid=20398892845&mkgroupid=154
424565809&rlsatarget=pla-
1585159291611&abcId=9317279&merchantid=6296724&gclid=CjwKCAjwnOipBhBQEiwACyGLuuVptCuw4_IiIpkFXB8xUkWEzj4jS5xGRNkASwF7xH2Zo4zMNf0JuhoCIN0QAvD_BwE
You might consider something like this. They're kinda clunky in a way, but so are the hydraulics in general on the 165. You really don't have a lot to work
with no matter which way you turn. If you already have a dedicated loader valve then this would allow you to supply it much easier than the the unit you
pictured.
https://www.amazon.com/hydraulic-selector-diverter-1860100M95-replaces/dp/B07CQSW3J1
Try this one.
Yes, a simple diverter valve. I've installed a couple of them and they do work. Probably as well as anything on those tractors.
That example has only 2 ports but that isn't the only option available. Do a search for Massey Ferguson 135 diverter valve to see other options.
I'm not sure why you would need more than two ports. I'm quite sure your loader valve will operate with one pressure and one return line. In fact, you may be able to find a sump return somewhere on the tractor and only need a single pressure port. More than one option here.
