620 John
Check the flywheel for cracks. Just pop the inner cover off the flywheel cover and look at the flywheel the best you can. I've seen a few B/50 flywheels cracked. They work loose for whatever reason and then someone comes along and tightens it and cracks it.Thanks for the replies everyone. I‘m thinking either a B or 50 might be ideal for my needs/wants. If I wanted the bells and whistles, it’s hard to beat for the hp and price the Massey Ferguson 50 diesel - which I have two.
I need to do some more reading and actually see one of these tractors.
Any inherent issues with either a late model B or 50?
Thanks for the replies!!!
Also engage the clutch and rock the pulley back and forth. If the pulley moves a little without turning the engine then the clutch driver is loose which is a similar headache to the flywheel. My experience has been the B's are more prone to the flywheel issue while the A's and 60's are more prone to the clutch driver issue, but either issue can occur with about any Waterloo 2 cylinder.
