Dan S (NY)
I have an MF231S with the Perkins 903.27 engine and after replacing a broken oil pressure light sensor I noticed the oil light has a faint flicker at all RPMs. I just recently got this tractor so I don't know the history but it only has 580 hours and runs really well. The oil and filter have just been changed (15w40 / Napa 1515). I temporarily installed a pressure gauge so I could see what kind of pressure I had and the needle is bouncing quite a bit. This is a relatively cheap gauge and probably has no damping but should it it bounding around like that? Below are two links to videos showing what it is doing. I only had it running about 5 minutes before taking these videos so its not warmed up, and when I have more time on another day I will see what it does and what the pressure drops to when warmed up more. I read someones speculation on a similair questoin that the oil pressure port is from the camshaft feed and may be pulsing as the camshaft rotates..don't know.
Another thing I am looking into is there a some air puffing back out of the air cleaner seal which increases with RPMs. I am thinking that no one has adjusted the valves since new and the intake may not be closing long enough and allowing a little blow back. At lease thats what I'm hoping. I will check the valves once I get the service book this week.
Any thoughts on these issues?
1200 rpm fluctuations
idle fluctuations
idle fluctuations
