finally got the U's water pump apart after waiting for a dremel tool from Santa for a couple years and then puddles to dry in the work area...Amazing what grinding a rusted mis-shapen pin into a solid surface to strike with a punch can do for effective pin removal.
I also found a pin at Fastenal that should be identical to the original groov-pin (their illustration on web and in paper catalog is wrong): #11104742. 3/16x1. Not sure about the hardness or anti-corrosion treatment, but it's at least a groov-pin type.
The "incorrect" roll pin usage goes back to the dealers in my opinion. There is a NOS box of parts on the farm that was purchased in the 70s, the impeller seal, shaft bushing, shaft seal, and a roll pin are all stapled together in a parts bag.
my questions: What parts do you reuse or eliminate when doing the impeller seal? What's supposed to be different between old/new? I'm observing some differences. The original has a retaining ring on the impeller for the seal (damaged when removed, seemed rotten). Also it looks like the replacement impeller seal design has been simplified, there is no inside part to fit the shaft tightly. The parts kit i got from Welters has only the impeller spring loaded component, and the oil seal.
any dos and don'ts while i'm in there? Going at it with the I&T for a UB.
thanks
karl f
thanks
karl f
