casecollectorsc
- Location
- E central SD.
With the new system I could load pictures biff, bam, pow. Now none of the thousand pictures on the laptop or my phone load...did I miss something?
I just uploaded one to a TEST post, no problem. Properties showed as 2MB on my computer.With the new system I could load pictures biff, bam, pow. Now none of the thousand pictures on the laptop or my phone load...did I miss something?
Soooo, how do I find out what size mine are?? Loaded fine a couple weeks ago from the same laptop and same phone. And how the heck would you change it. Have been putting pictures on YT for 12 years without a problem till today.I just uploaded one to a TEST post, no problem. Properties showed as 2MB on my computer.
On my computer I can right click on a picture and get a drop-down list that has properties as a selection on the bottom of the list. Clicking that gives me info about the picture including size. I can't say how you can find that info on your computer or phoneSoooo, how do I find out what size mine are?? Loaded fine a couple weeks ago from the same laptop and same phone. And how the heck would you change it. Have been putting pictures on YT for 12 years without a problem till today.
It's been my experience that since we fixed the size issue on here a couple of weeks ago, it takes much larger photos than the old system and it's not as picky as the old system concerning the filename. After the last change I've heard no problems with photos. Are you dragging and dropping them into the window or pressing the Attach Photos?Soooo, how do I find out what size mine are?? Loaded fine a couple weeks ago from the same laptop and same phone. And how the heck would you change it. Have been putting pictures on YT for 12 years without a problem till today.
I've tested up to 4.8MB without problem this morning. I don't have anything larger to try other than an 7.8MB photo which was too large. I expect the limit is at 7MB or so. It was set to try and be like the old system.Soooo, how do I find out what size mine are?? Loaded fine a couple weeks ago from the same laptop and same phone. And how the heck would you change it. Have been putting pictures on YT for 12 years without a problem till today.
I just uploaded a 6.27 MB to the Test ForumI've tested up to 4.8MB without problem this morning. I don't have anything larger to try other than an 7.8MB photo which was too large. I expect the limit is at 7MB or so. It was set to try and be like the old system.
Thanks, I just didn't have anything that big. My phone even when I hadn't fixed the settings would only produce a 4.something MB file.I just uploaded a 6.27 MB to the Test Forum
Think I found the problem...YT must have size limits on pictures now and did not before. Pictures in my laptop range in size from 3.8 to 8.8 on pictures taken at the same time. So the smaller ones will load and the bigger ones won't, even though they were taken at the same time. Have to check each before posting and figure out how to re-size. Thanks for the help.With the new system I could load pictures biff, bam, pow. Now none of the thousand pictures on the laptop or my phone load...did I miss something?
Size limits are not new. The limit with the old software was about 7MB, and in discussions above in this thread and the thread "Question for Chris", we proved it to be about 7MB on this software yesterday.Think I found the problem...YT must have size limits on pictures now and did not before. Pictures in my laptop range in size from 3.8 to 8.8 on pictures taken at the same time. So the smaller ones will load and the bigger ones won't, even though they were taken at the same time. Have to check each before posting and figure out how to re-size. Thanks for the help.
Jim is correct, We are matching the photo size on the old server.Think I found the problem...YT must have size limits on pictures now and did not before. Pictures in my laptop range in size from 3.8 to 8.8 on pictures taken at the same time. So the smaller ones will load and the bigger ones won't, even though they were taken at the same time. Have to check each before posting and figure out how to re-size. Thanks for the help.
Old limits must have been higher than 7MB as I have posted some of these pictures on the old format and the new. Some of them were 8.8 that were posted earlier in the week. The change must have come in the last few days. What I don't understand is that pictures taken within seconds of each other go from 3.8 MB to 8.8MB instead of all being close to the same.Size limits are not new. The limit with the old software was about 7MB, and in discussions above in this thread and the thread "Question for Chris", we proved it to be about 7MB on this software yesterday.
There is a possibility of getting a photo in much larger than 7MB. If you look at the other thread here with Absent Minded Farmer. He is managing to get in very large photos (13.3MB) and jonofnewhaven also got in one that is 10+MB. I'm trying to figure that out because it technically should not happen. My current thoughts (untested) are that pressing the "Attach files" button is not the same as clicking the icon for "Insert Image". One may be using an addon we installed to handle large photos, and the other may not be and is using the default size specification.Old limits must have been higher than 7MB as I have posted some of these pictures on the old format and the new. Some of them were 8.8 that were posted earlier in the week. The change must have come in the last few days. What I don't understand is that pictures taken within seconds of each other go from 3.8 MB to 8.8MB instead of all being close to the same.
Quora says file size is affected by the details in a scene and/or how many different colors are involved.What I don't understand is that pictures taken within seconds of each other go from 3.8 MB to 8.8MB instead of all being close to the same.
Thanks for answering that. I didn't have a response on that issue (why a phone has a such a range of sizes it takes). I would guess that zooming and unzooming might have an impact. On my phone there is also a mode where it shoots several images within one and then takes the composite. That generates very large file sizes and I've never been able to figure out why I would want it, so I turned it off.Quora says file size is affected by the details in a scene and/or how many different colors are involved.
Assuming no camera settings have been changed.
