First, thanks to JMOR and Tim and others for the help with wiring and identifying the generator. Pardon me for plagiarizing the artwork from JMOR's pictograms. Thanks to Tim for the education regarding tensioners, which explains both the overheating and dead battery.
The tractor is a 2N with a '48 no serial number 8N engine and an 8N10000A generator. The regulator that came with the tractor did not look like any of the 8N10505s.
Did I get this diagram right? I don't want to fry the new 6V battery or anything else now that it's warm enough to start working on it again. Warm for MN anyway.
Edit: OK, I have taken off the 'Don't trust this' disclaimer. Thanks, deanstoybox.
IAW does mean in accordance with and it is from long years of working with military documents, and SB 78 is service bulletin 78.
If it is wrong, I will edit the image and this post to correct it and replace the image so it won't be here for anyone to use and screw up their tractor.
The previous owner installed an 8V battery. It didn't last very long, probably due to the missing tensioner. The generator was putting out around 9V when the belt was tight. It did charge the 8V battery, but the voltage reading suggests that the old regulator wasn't working. It looks too big for any of the 8N regulators and it has no identifying markings.
This post was edited by Dave G9N on 02/15/2023 at 10:03 am.
