drumwire-HT
Hi All,
I know little to nothing about electrical issues and need some input. The other day I was running a 4' rotary cutter on my YM 2000 for about an hour and a half when I shut the tractor down to take a break. I came back, turned the key and NOTHING . . . not even a click. The battery is about 6 months old and has shown no signs of fatigue or corrosion to date. Normally, the tractor fires up immediately.
So, I got down and with the key in the OFF position and checked battery cables, only to find the positive post slightly melted -- maybe about 1/6th of the post had melted away on one side (again it was the positive battery post's soft metal melting, not the cable or connector to the battery cable). I immediately removed the positive wire from the post for fear of the battery exploding and experienced excessive sparking while removing it (again key was in off position). I looked at the wires to the starter, alternator, and ignition but didn't notice anything melted, pulled away, broken, or otherwise out of the ordinary that would reveal a short (granted I did not trace them carefully). The positive terminal that connects to the battery had a little rust on the metal connector attached to the cable (like always) but nothing new or excessive. I don't think it is corrosion at the terminal. The post was clean as a whistle, except for drips of metal from the slightly melted post. I felt of the starter, and it was extremely hot to the touch.
So, I let it cool off over night, came back today to try again and when connecting the positive post to the battery (key in off position) got excessive sparking / beginning to melt the post gain immediately. So, same problem / no change. I had hoped starter hung up and got too hot and by chance might start, but no luck. Let me also say that this is the first time I've had any issues with the tractor failing to start or turn over. This came as a complete surprise. It has a Denso or Danso starter from Japan on it with a Yanmar label, but I'm not sure if this is the original. I realize starters can be rebuilt and solenoids can be replaced, but at $100 for a starter I'll just replace it. But . . . I'm thinking there has to be a short somewhere (melted wire / hidden corrosion in the cabling / cut cable), or the starter or solenoid is bad. I'm doubtful it is the switch itself, but what do I know? Thoughts?
Again, I'm not much of a mechanic. So, if you have other ideas or I'm overlooking something I'd appreciate your input.
Thanks!
Thanks!
