LarryMaine
Just finishing up a full rebuild on my 9n hydraulic pump and am wondering if anyone has any suggestion on whether or not to use assembly lube on the parts prior to assembly. I used STP on my engine rebuild parts, but that is oil based. Would STP negatively impact my hydraulic fluid as it wears out from the pump parts? Did not use lube on prior pump rebuilds with no apparent problems. Also, does anyone have a hack for removing the very bottom sockets in the valve chamber body (part # 9 in figure FO153 in IT manual FO-4)? Mine just wont come out, even with a magnet. Thanks all, Larry.
