I recently purchased an 8N 6v......took the hood off today and took a look at the wiring and it is a mess.
I have searched and searched to no avail for the correct schematic to completely rewire it.
This is a front distributor (and the singe small coil wire befuggles me also), and the gen is a 3 wire.
Those are the main things that I can't locate. The resistor block looks different (I know, they can change them) also.
Now, the gens I've seen have one wire, and coil must be for side mount distributors cause they have a standard (what I'm used to) main coil wire to distributor and two terminals.....mine has one small wire which should be standard.
The schematics I've seen do not have my setup.......would someone please help me with the correct schematic?
Thanks to all
Thanks to all
