Just rebuilt the engine in my IH 350
New Sleeves, cam Bearings, cam cleaned up, main bearings, rod bearings m, pistons and new rings.
Did not turn crank but did mic it. Looked good.
In the rebuild process pulled oil pump apart and there was excess wear on the shaft that drives oil pump. Built up shaft with weld and turned it down on lathe.
Finally got everything back together and started engine. However only had 15 pounds of oil pressure that’s with engine warmed up. New oil gauge.
Using 10w-30w oil.
Could be gauge
Could be pump
How would you troubleshoot problem?
Using 10w-30w oil.
Could be gauge
Could be pump
