Jim Mitchell
I completely tore down and reassembled my A3.182 Perkins engine in my Massey Ferguson 50. Now it won't start, even on ether. It doesn't even try except during that brief period that it takes to consume a shot of either.
Since there are a whole lot of places that could be causing my problem, I was hoping that someone could help me pick apart the troublehsooting to narrow down the likely source of the trouble. And, yes, this is my first rebuild project. The engine was running before I took it apart, even with one broken rocker arm.
I am reasonably certain that the timing gears are on correctly. I had to take them apart once already because I put the cam gear on without keeping track of the position of the D on the gear. That corrected the problem I had with the engine exhausting out the intake.
Is it possible to correctly line up all the timing marks and have the engine be 180 or maybe 120 degrees out of time? I did check the flywheel timing mark before I reassembled the gears.
I took my injector pump apart and put new rebuild kit parts in it.
The lift pump has been replaced, as have the two fuel filters.
I get fuel at the injectors but it doesn't seem to spurt out like I think it should.
I am reasonably certain that the entire fuel system has been bled of any air.
I tested the spray on the injectors and that was ok.
