Still working on 37 f12 and can't get it to start. Getting good spark and have reset ignition timing several times but wonder if I'm still off. Currently, when #1 cylinder is at TDC based on flywheel mark (DC 1-4), the distributor rotor is contacting #1 and points are opening when nearly fully retarded. The impulse doesn't snap until a little past TDC however. I have good compression and have put gas in both carb and cylinders but nothing. When I had the timing retarded more, got it to pop once but that's it. I have attached picture showing rotor and points just after impulse snapped in current setting. Not sure if my timing is still off or need more or less gas. Any advice appreciated as I'm getting tired of cranking.
