dbsoundman
This tire isn't terribly old and has minimal weather checking, but the rim is all rust jacked and leaks fluid from who knows where. I'm not sure if the rim itself is full of fluid or if the tube has a small leak, as it takes a while for it to visibly air down but there's always a puddle wherever that tractor sits while parked.
Anyway, I don't have much good tire experience, the last set of tractor tires I tried to get off rims I ended up just cutting apart with a sawzall. I tried driving on top of those tires, pressing them with another loader tractor, etc. but it just didn't work. Is there a good technique to break the beads on these old setups or should I just send the whole tire and rim off to pasture?
