International 2 bottom plow coulters
Hi, Im not very experience with plows. I've acquired a very heavy duty 2 bottom plow. It does not have a metal tag but I can read the International faintly in the paint. The coulters are in very poor condition. They are 16 inches diameter serrated and have a center riveted on hub with kind of a cone shape center. Is there any sources you can lead me to for replacements. Any help would be greatly appreciated. Thanks Mark
Duffield is a good one .
YT has plow peddlers out of republic,Ohio
Dylan lynch is southern Indiana
Andrew Ginter in south bend .
All these are very helpful to get your plows working as they should. Ask them how.
Shoup has them but I don’t think they can support you with field knowledge of these above people have on your plow identification and operation.
If all that is wrong is badly worn blades it may be possible to replace them from a place like Shoup. Size is important but bolt/rivet pattern and the size of the hoke in the middle is also so if you buy replacements that information is needed on the new ones before spending the money. Sometimes it works, sometimes it don't.
Thankyou so much WESnIL, 560Dennis, and Charlie M. You International guys are great. I'll check those sources out during weekday hours when their available. Charlie M are you proposing I possibly could just drill out the hub rivets and buy just the serrated disc and reinstall the hub? Mark
I did that on the John Deere plows I have but it was over 30 years ago and the blades were available from John Deere at that time. I used bolts for the new ones.
I have any parts for the International plows you should need. I have new coulter blades 16 inch for $40 . Thanks Steve 419-618-0017
