502 BBC heads question ?
drsportster
Do all the 502 Chevy Big Blocks take a standard cylinder. head In the 427 days you had to know if you had oval ports or rectangular ports is why I am asking about the 502 head Is there only one possibility ? I f you were to order a 502 head ?
A simpler alternative is a Deere D engine - 501 CID with only two bores. Similarly, there were a couple of head variations for that one, too.
What sort of induction are you using?
How do you know which your 502 takes ?
Depends on its original usage. The 502 was never factory installed in a vehicle, only over the counter. Most 502's were sold as performance engines and will have rectangle ports. GM performance did sell a truck 502 with oval port heads as a 454 replacement. Chamber volume would be selected based on desired compression ratio.
