dbsoundman
Hi all, I just picked up a Dearborn 22-11 post hole digger with a nice 12” auger bit, but the previous owner said the drive shaft was too long for his 8N tractor. I took a look at it today and noticed the shaft is a fixed length, not the compressible shaft I thought typically came with these things.
I can find replacement shafts no problem, but I’m not sure if they will mate up with the gearbox. I see a U joint at the gearbox held on by a castle nut, and the replacement shafts I’m finding look like they’re supposed to slip over the fitting on the gearbox and attach with a shear pin. Do I need a special driveshaft or will a new one fit? Bear in mind I’ve had all of 10 minutes to look at this thing so far.
