Flywheel Timming Marks
Catman977
Hi everyone: I have a Ford 821C with a fresh rebuild engine. I can't seem to locate the timming marks on the face of the Flywheel. Anyone have this problem? Thanks Max
I can never remember which surface to look on. There are two surfaces visible, 90 degrees apart. I sometimes hold a green nylon scrubber pad against it while running to shine it up.
Roll your engine to near TDC using air blowing in/out the #1 spark plug hole to get close. then look for the marks, The are on the flywheel NOT the ring gear. After finding mine, I put some orange paint on the ring gear where the marks are.
They are not easy to see. If there is any clutch dust or oil at all you will not see them. Find TDC using you wrench. Then look.
