I’m looking for some advice from folks here with real-world experience before I move forward on having a shop built.
I’m in central Kentucky, near Lexington, on flat ground. We get a steady breeze most days (8–11 mph on average), and my biggest concern is moisture—the water table is very high. I can’t dig a post hole without it filling with water before I’m done.
The building I’m planning is 24 x 32 with a 32 ft lean-to, and it will have a full concrete floor with a vapor barrier.
I’m considering three options:
1. A turn-key pole barn
2. A roof-only pole barn with concrete, (letting someone else do the hard part) and I finish the walls and install the garage doors myself.
I’m very familiar with pole barn construction, but in my case I would need the Post Protector system to prevent rot. Does anyone here have experience with post sleeves and wet ground? How well do they actually hold up long-term?
3. A tubular metal frame building like the carport-style structures, anchored to concrete
On the metal building option, I like that everything is anchored to the slab so there are no posts in the ground to rot. However, I do have concerns about durability. Given that we’re under constant wind load, do the screws tend to loosen over time? And how do those roll-up doors hold up? From my experience renting storage units, they seem pretty flimsy.
I’d really appreciate any insight.
Thanks in advance.
Thanks in advance.
