Searched and found a small bit of info from 2007 but thought I might get a better run down with a new post. For some reason, I've got the itch for a 460/560. WF, 3 point hitch but will add the hitch kit if I have to. If it's just going to be a roadside mower and pull a hay rake from time to time, do I care whether it's a 460 or 560? Prefer a gasser just because it will not get a lot of use and will sit long periods of time, I can clean or rebuild a carb many many times over compared to having a pump gone through. Won't need the additional HP of the 560, mainly depends on what I find depending on condition and distance from me. I assume both had optional power steering, and both have an independent PTO, so what else am I looking at for differences that actually matter. Do both have TA? I remember one of the two having a weak diff or axles or something along those lines, but I'm not going to be pulling anything that concerns me there, doubt it will ever pull anything ground-engaging.
