Char-Lynn Power Steering K-445-A
kew71
I need to rebuild the steering box on a Char-Lynn K-445-A power steering setup. Things came apart when I pulled the steering wheel during a restoration. Any idea where to source the seals, and such or a full re-build kit?
Looks like some are available through the dealer.
The following is a link to an online parts catalog for a dealer in PA. I choose the 600 per Hobo’s linked manual which indicates that is a model it is used on.
Messicks Ford 600 PS parts
Here is a link to the manufacturer’s online parts catalog
CNHI Ford 600 PS parts
Those links will allow you to look at all parts diagrams for your tractor. If you have a different model I can instruct you how to switch to it, if you need more info let me know.
Did you find the parts? I do have a Char-Lynn PS system I took off a model 841, should be the same as yours. It was working when I removed it.
I just need mine rebuilt. It worked. But took the tractor apart for restoration. How much?
