WTB WD clutch alignment tool. PM me. Thanks.
chico1
Hate to pay the shipping they want for a piece of plastic I will use once in the remaining short time here on earth!
Don't buy one. It is easy to do without one. Just tighten pressure plate bolts enough to hold the clutch disk from moving underr it's own weight. With a flashlight and a screwdriver move clutch disk up close to center. Then sight along splines of clutch disk, you can move it around with the screw driver. Minor diameter of splines are same as pilot bearing bore. You can line it up in a minute, done it many times.
Most of the universal alignment tools for auto and light trucks will work on a single disc clutch. If the throw-out bearing/bushing is too big for any of the adapters with the tool, pick the closest fit one and add a few wraps of electrical tape to bring it up to size.
Either eyeball or a close fit dowel or broom handle will get you there with a little patience. Might need another set of hands to tighten PP bolts
