I have a 50s TO35 with the dual clutch/live PTO. Gas engine. I started her up after winter, everything worked fine, I parked it after using it for a hour or two. The next day I went to start it and the clutch didn't work. I figured it might be stuck, so I drove it around in high gear, pushing the clutch over and over, brakes, etc. No luck. I adjusted the clutch pedal, no luck. So, I went ahead and pulled the loader plate off so I could get to the inspection place. The clutch pedal operates the throwout bearing, the fingers move. None of them are missing anything and they all move how I expect they should.
I don't see a lot of smuck or rust on the clutch parts themselves.
I tried to find a video of someone unsticking one from the inspection hole but I can't find anyone who explains exactly what I'm supposed to be prying loose in there. I spun the engine over by hand and I don't see anything obviously wrong.
A video of what is supposed to move when you push the clutch while you are looking through the inspection hole or a picture with a circle drawn on it or where I should pry at?
