I Installed a "ONE WIRE Alternator" on my CASE 930,(6 speed,Gasoline engine).....,,100 % satisfied.yup,i understand it origionally had a generater.this was redone 12 volt at some time. Where do i find a one wire alternater? Any Delco on amazon?
thanks for putting up with my questions.I need a lot of help getting this old tractor the way i want it.
Thanks
Nice!I Installed a "ONE WIRE Alternator" on my CASE 930,(6 speed,Gasoline engine).....,,100 % satisfied.
As soon as the 930 case fires and is at minimum speed the alternator is charging..........
I Installed a "ONE WIRE DELCO Alternator" on my Massey Ferguson 35 X (3 cylinder Perkins diesel),....100 % satisfied.
As soon as the 35 X Perkins fires and is at minimum speed the alternator is charging..............
I shall check for a PART # tomorrow, as I have a new "ONE WIRE DELCO Alternator" that shall be installed on y McCormick W9....
Bob............
You as the owner, you can do anything to your Tractor that you decide to do.........HOWEVER,your Tractor Engine may not have acceptable oil pressure....Nice!
Another question. Can I use rotella t 10 weight oil in the te 20? Am I correct it is a good oil for older tractors?
What is "rotella t 10"? If it's 10 weight, that is too thin. 30wt winter, 40wt summer.Nice!
You should clarify which compartment you are asking about oil for.Nice!
I would not use it in either.i have 12 liters of straight 10 weight oil .Can i use this for the old fergie t20 engine?
or would it be better used for the tranny /rearend?
No! Pick up a bucket of UTF at an auto supply.i have 12 liters of straight 10 weight oil .Can i use this for the old fergie t20 engine?
ok.I do have 21 liters of UTINo! Pick up a bucket of UTF at an auto supply.
This is a "ONE WIRE" Delco Alternator....ok.I do have 21 liters of UTI
I see one on Amazon. Says fits massey,and. Chevy. 63 amp or so. . One wire.This is a "ONE WIRE" Delco Alternator....
There are "other single wire Alternators", "that are more compact", also "look more professional installed",on Vintage equipment....
Pic is of my Case 930 6 speed,Gasoline Engine......
"YT" has a one wire Alternator advertised,and a universal mounting Bracket,that you may have to have a skill set to modify..
Bob..
If the Alternator is a direct installation,turn the key on and run........you hit a home run.....I see one on Amazon. Says fits Massey,and. Chevy. 63 amp or so. . One wire.
Would that do? I'm thinking about getting that for the 434 diesel tractor. It's alternator is shot also.
Then later on I'll get the same little alt for t he fergi.
Yes I was looking,and I believe I can frakinStein a bracket. ThanksIf the Alternator is a direct installation,turn the key on and run........you hit a home run.....63 amps is fine.
No guarantees you will not have to rework the mounting bracket.
Depending on your skill set............
On my Case 930,I had to cut shims / spacers made from 3/8" pipe nipples to align the drive pulleys...no big deal.
Bob.....
Also. Will it hurt to add a bit if seafoam to the gas,just to clean the top part of the motor? It dosnt smoke..but what's your take on this?Yes I was looking,and I believe I can frakinStein a bracket. Thanks![]()
Or even in . The oil?Also. Will it hurt to add a bit if seafoam to the gas,just to clean the top part of the motor? It dosnt smoke..but what's your take on this?
I have NEVER added Seafoam to an Engine crankcase,as to the engine oil.Or even in . The oil?
I have added seafoam to the Fuel Tank on my TEA-20,as well as my John Deere D's.Also. Will it hurt to add a bit if seafoam to the gas,just to clean the top part of the motor? It dosnt smoke..but what's your take on this?
