Ferguson 30 Steering Linkage broken. How to Fix?
JavierG
As I was repairing other issues on my TO-30 this part of the steering linkage came off. What parts are needed and how do I go about fixing it? Also, I notice all the other grease points have the rubber completely worn out to the point where grease would just come out.
Any advice will be appreciated. Thanks everyone.
Looks like your tie rod end is worn out. A new tie rod end will fix this problem. Might want to check the one on the other end of that tie rod and also the tire rod on the other side of the tractor to see what kind of shape they are in.
Check out the front axle drawing (page 42 in the left index) in the parts book to get part numbers.
Hopefully this link works to get you to the online parts book.
TO 30 / TO 20 parts book
Find the part numbers and use the part number in your search. I expect YT may have the ends you need.
Thanks tldnc I will do exactly that!
