Jim.ME
- Location
- central ME
Documenting what I am ordering.
I called Pertronix and gave them my distributor number from the side of the distributor which is #353898R1. That is apparently the original.
And the tractor is 12V negative ground.
They gave me this kit and coil to order:
IHC 302xxx-534xxx Series 4 Cylinder Ignitor® Electronic Ignition Conversion - 12 Volt Negative Ground - PerTronix 1442
Electronic Ignition Conversion Kits to replace original mechanical points & troublesome factory ignition. Dependable, maintenance free, and easy to install. Never Replace Points Again. The Original Ignitor is ideal for restorations.pertronixbrands.com
PerTronix 40611 Ignitor Epoxy Filled 40,000 Volt Ignition Coil with 3.0 Ohms Resistance in Black
Features & Benefits 40,000 volts. Available chrome plated or black for that "stock look". For use with inductive ignition systems. 1.5 or 3.0 Ohm primary resistance values available. Legal in all 50 states and Canada. (C.A.R.B. E.O. #D-57-21) The Flame Thrower canister coil is designed to mate...pertronixbrands.com
$248.49
Then I called Steiner for the rest, which was cap, rotor, wires, and plugs:
Steiner total $84.68
Total $333.17
Thanks for the help!
This site's software blocks links to many sites they see as competitors to the products they sell, such as the one you purchased from, which is why it shows "external_link" instead of the site's name. Can't blame them for not wanting to advertise for a competitor.
