can I weld a small bracket to the trumpet ends of the axle on my Ford 8N
Astroguy
I'm wondering if I can come up with a different system for my 1949 Ford 8N. the front loader operates by having the three-point hitch going full up position to about 90% which at this point is blocked with steel brackets. then I opened the valve to the front end loader and I can operate the front end loader. see pictures below
it works reasonably well but it is problematic and does jam occasionally, as I said see picture.
I'm wondering if I can simply weld a link of chain to the trumpet of the axle the proper length so I can easily connect and disconnect the three-point hitch from rising to the full height. hard to explain what I'm talking about maybe you can figure out what I can hit the photos but I'm really asking if I can weld to the trumpet with a 220 A stick welder
That set up has always been a slow pain in the back sides set up What you need it to install a hyd pump that runs off the crankshaft and that way you have both when you need both
At home on the farm , we just used a log chain to hold them down.
yes absolutely the chain would be nice to hold them down. and that is my plan but I guess my question best would be put as, can I weld something to the trumpet of the axle without causing internal damage.
I want to just simply weld the chain to the axle trumpet so I can quickly and accurately attach and detach these with a simple pin.
I'm just trying to figure out what's inside of the trumpet that I might damage if I weld a piece of link to the outside of the trumpet. is there space or is it a tight grease fitting
The trumpet is cast iron, and you will not likely be successful at welding to it. Not likely to damage anything inside, but not likely to hold and may make a weak spot that could lead to failure in the future.
I would think about a band clamp like you already have, or a bracket that catches a couple of the lower mounting bolts to attach your chain to. If you use the bolts as a mounting point, you will need to replace them with bolts that are longer by the thickness of your bracket.
you're absolutely correct, I have welded cast iron before but only in low stress components. don't really know what I was thinking there. thanks
