OldFart187
1953 Ferguson TO30
- Location
- Somers, CT
My front axle bushing had been replaced with a DIY repair bushing 2-5/8 long, likely intended to help with the extra force from the front end loader. The housing was removed from the tractor. The (dry) bushing had rusted to the hollow pin and had to be driven out with a sledge hammer, not a pretty sight. A grease fitting setup will be part of the rebuild but the stock replacement bushings are a maximum of 1-3/4" long, maybe not ideal for high front end loader forces. One owner used two stock flanged bushings end to end but I'd prefer a single bushing.
Since the load is on the bottom of the bushing/pin contact area, that's where the grease needs to go. A hole will be drilled through the top of the axle to the center with a grease fitting on top. If a single bushing is used, a 1/16 deep groove, 1/4 wide machined in the OD of the bushing will allow the grease to get to the bottom where two drilled holes near the bottom of the bushing lets it get pushed up and in. The bushings will be secured in the axle either by a press fit or with loctite. If two bushings are used, a small axial gap between them gets the grease uniformly around the bushing/pin gap.
Are bushings longer than 1-3/4 available? I'd prefer not to make a custom one. It doesn't need to be flanged.
