Two Ford 9n’s
Killa
Location
Valley Mills Tx
I have two ford 9n tractors. One has a serial number of 9N16187 the other has a serial number of 9N188707. I have tried to decipher the year of each but not positive it looks like both maybe 1940 models however the tractors don’t look similar can someone help me find out the year models? I am new here and just getting started on refurbishing both. Thanks
In what way don't they look similar?
Upvote 0
Thank you sir! The way I read it is the 9N188707 is a 1945 and the 9N16187 is a 1940. Please correct me if I’m wrong.
I think you have the numbers right. The one you called rusty would be a 1945 2N by the serial number. And as someone else said, that extra shifter is for a Sherman auxiliary transmission. Most likely a step-up trans. It would give you 8 forward and 2 reverse speeds but also changes the PTO rotation speed when in the step-up position.
Upvote 0
