Yes. If not pinned securely in the correct place it will not move the throw out bearing correctly.I noticed that theres only 1 pin on the fork, the other ones missing, but it looks like it's still functional. The fork can get misaligned and cause issues with the throw?
I recently bought a Ford 1900 with the dual stage clutch. I should say I noticed the gears liked to grind when shifting, I thought it was just me getting used to having to idle down and wait a second before shifting and I'm still unsure if it was my error or something in the tractor. My second day using it I got it stuck plowing in the morning. I dug it out and parked it. That evening I went to start it up and I couldn't get it into gear, it would just grind. The clutch pedal had no resistance except for a bit at the last inch of travel before bottoming the pedal out. So I pulled it home and assumed I would have to split the tractor and fix something with the clutch. Then I started reading how often these clutches get stuck against the flywheel and thought I'd better do my best to figure out what's going on before splitting it.
Viewing through the peep hole on the side of the housing I can see the fork throwing the bearing forward but the throw hardly makes the release fingers on the pressure plate move (I can only see the side view of the pivoting point of the fingers) as though the fingers are already in the depressed position. Is it possible that the clutch froze to flywheel in such a short time period having used it earlier that day? Anything I should try to pry against through that hole or through the starter mount hole?
Any advice would be greatly appreciated before I open this thing up.
When I replaced my two stage on a Ford 961 I took it to a local dealership to have them set it up to spec.I did a clutch job on on of them years back . what a pain in the drain . At times an old Oliver dealer would call me to come up and help out when they got buried . at that time i did NOT own one metric wrench . I had to go BUY everything in metric .. Nothing on that job went easy everything fought me . Back then you could not buy a pressure plate assembly , everything was piece meal , You had to BUILD that pressure plate and it had to be done on a fixture and everything had to be set to spec's by the set up gauges . Welp we did the job and it worked and i told the dealer to NEVER call me again when it involved one of them again . He had to borrow the fixture from the ford dealer and the BOOK . He use to get me into some of the worst jobs one could ever have nightmare about.
