Tools you didn't know you needed until you had them
Teakettle
Location
New England
Surely some of you have had the experience that you bought a tool for a one-time project, and then you found yourself reaching for it all the time. My most recent example is a plastic welder, which I bought because I was helping restore a car where some of the plastic interior and underhood parts were no longer available new and we needed to repair the pieces we could get our hands on. Then once I had it, I kept running across broken plastic things around here ranging from appliance knobs to toys, where in the past I would simply have bought new components but now I don't have to, and i can even correct the structural mistakes that the original engineers made.
I still passionately hate under-engineered plastic parts, but since this tool came with rods of a half-dozen different polymers I have compatibility with a wide range of materials. I always use it outdoors or with a fan going, as I know very well that this is not a wholesome activity for one's respiratory system.
My previous such tool was a great big hydraulic press. How did I ever live all those years without one? Before that it was a pneumatic trim nailer.
What's your example?
Gotta be my multi-tool saw.
I would have to say a Roberts Laminate Floor cutter.
Bought it for one job and haven't used anything else except a 20 volt multi tool and a drill with hole saws since to cut laminate flooring. It's nice to get to the end of a run, mark the plank, cut it and move on without having to get up carry the piece to a mitre saw and back. And you have no saw dust to clean up. I have used it to install thousands of feet of laminate and vinyl flooring over the years.
My AC-DC welder and the Torch set!!!
20 volt Dewalt 1/4” impact
A metal lathe and a 16 lb sledge hammer.
Madtown Tools line wrench for Ford 4.6 egr removal . I can’t do without to clean the goop out of the holes blocking exhaust gas hole recirculating ports . Causing engine code. Was the tool of the decade past . Saved me a lot of cash.
one i have is a small deburring machine, tub type with about 2.75 cu\ft capacity. i use a media that does not damage threads so if i in a project of rebuilding something i dump items in with a little soap and let it run for an hour. item come out clean and i can do something else as its doing its thing.
