8nTroubleMan
Long story short.. I own 5 acres with 2 driveways, one being in a forsted part of the property... I just needed a simple 3 point tractor, but finacally buying the property has put me behind.... Dont worry I had the genious idea of getting a 1952 Ford 8n! I've been shopping for tractors for about a year...last weekend this one popped up and the seller was close to me and ready to negotiate.... well boy o boy as a guy that buys cars and motorcycles all the time the excitement got to me and I over looked ALOT of red flags... The owner started it and ran it up and down his driveway for me, but i failed to catch the small things.... So I give him $1500 and get it loaded onto my trailer... I get it home and it runs TERRIBLE and wont stay running... I started by ordering a new tank and running compression tests on cyclinders dry and cold engine. Avarage was 98 PSI, cyl 1 93.9, cyl 2 92.6, cyl3 101.9, and cyl 4 102.3psi... I didnt want to throw money on this tractor if the engine was roached... So far I'm all in $1,769.... I just need a miricle to get her going... I just need to use her twice a year to grade out the driveway and some other random part of the property...follow along with me as I try to get her to run good...and not get divorced in the process....
Negatve (so far)
Positive
New Parts by me
Negatve (so far)
- RUST in gas tank BAD...
- PTO leaking from PTO SEAL
- Fouled carb from running with ruseted gas
- low trans fluid due to leak at PTO shaft
Positive
- new distribturor
- front distributor
- clean overall tractor
- decent tires
- nice blade
- good radiator no leaks
- new guagues
- new battery
- new rotor, wires
New Parts by me
- $115 Gas tank new
- $29 carb
- $15 debrs bowl
- $98 PTO new PTO shaft wth 1 3/8 upgrade
- $12 new plugs
