KCTractors
- Location
- Central Wi
I think you did alright with the price. I would invest money in a good carburator.
John,Glad its running!
When you get time, it would be helpful to others, if you were to measure the jets, an post about how it runs.
John
Someone suggested that you remove that knob off of the steering wheel but didn't explain why. If you are running through some high weeds and the front tires strike a rock, the tires will be knocked to one side or the other. This will transfer the motion up to the steering wheel and cause it to jerk one way and the other. You can guess why that knob will be a hazard.
When you grip the steering wheel, don't grip it like you're choking a snake. In other words don't wrap you thumbs around the wheel rim. Keep them outside of it.
John,
I wish I could the Amzon carb is on its way back to amazon...the carb that came with the tractor had a jet so small it used the smallest of the jet wire cleaners..
wow god eye!! I went to go fix it and because it installed wrong the pin in the shackle is complete bent i will have to cut it off any idea what size those shacles are so i can get new ones??Believe it or not, there is a right, and left hand chain anchor. 9n596 is the right, and 9n597 is the left. Yours are on the wrong sides. Makes the holes the anchor shackes fit into too low...
This is correct![]()
