1940 John Deere Model A front wheels wobble.
Depends if it comes apart often the whole pedestal will be off the tractor and you will be going through it. I have pulled a sector right off easily to clean up pieces of a bearing on the steering shaft that came apart into the grease and I have had one stuck on so bad it took some persuasion. If the tractor has to be picked up off the ground you might as well go through the pedestal. If you remove the cover off clean the top and the sector comes right out try it and see what happens.
You might want to do those steering shaft bearings as well regardless of which direction you go
Thanks for the information.
You can try adjusting the clearance on the sector gear. But if it's been loose for too long it gets worn in the mid-range and will bind at the extreme ends of travel.
I've never done this, but years ago there was an article in Green Magazine by a guy who ground or filed the teeth on the ends of the gear to match the wear in the middle. Then supposedly he was able to adjust the gear so it didn't wobble or bind at the ends.
That may or may not be the way to go, but just throwing it out there. I suppose it saved him the cost of a new gear. Probably depends on how much you're going to use the tractor.
I suppose that could be done but depend a lot on his skills with files or grinder. If done it may not have enough adjustment in the eccentric bushing.
