What Is The Best GAS Utility Tractor From The 1970’s - In 2026 ???
Bill VA
What is the best GAS utility tractor from the 1970’s that is a good tractor for 2026?
I’m thinking engine parts/rebuilds/carb support in particular. I should think the rest of the tractor parts are similar to their diesel counterparts.
Farm chores, raking hay - maybe light loader work.
Thoughts - Thanks!
I bought a 430 Case a month or so ago. Neighbor is in a memory care unit and his wife is selling his 200 tractors by word of mouth. Nearly all are JD with only 3 Case, 43
0 and a couple VACs. Anyway the engine was stuck and I couldn't get it loose soon enough. Had a 188 cu in engine from a combine in the barn that I overhauled 25 years ago. Put it in the tractor. Two remotes, live power and draft o matice 3 point lift makes it a very versatile tractor. Plus almost 30 mph road gear makes for a nice tractor.
If I were to buy a utility from that era I'd be looking at IH 574, 674, 454 or similar. But then IH is my thing.
Oliver 550 or White 2-44 (same tractor)
Independent PTO, live hydraulics, power steering, disc brakes, 6 speed forward 2 speed reverse,
Parts through AGCO or numerous aftermarket sources.
Condition is the main factor, these are 50-year-old tractors.
This thread is really just going to be a lot of personal opinions. But on a similar note to the Oliver 550 mentioned above, the slightly earlier Cockshutts - 540, 550, 560 (the real Cockshutts and not the later rebadged Oliver 550) were also superb tractors - especially considering what else was available in that era (late 50's - I realize a little earlier than you're talking about). Fully independent PTO, finger-tip power steering (though had to be ordered as a option on some of the earliest ones), superb operator access and great layout. Common, dead-simple, and bulletproof Continental, Perkins, or Hercules engines (depending on the model), great gear patterns and speed selection, great three-point with fully independent hydraulics and draft control, built nice and heavy where they need to be, but still nimble tractors. Really just a sensible, comfortable, bulletproof, modern tractor.
Whenever I use our little 540 I think that, if I wanted to buy a new utility tractor today to use for the same purposes, I don't think I'd want a single thing different. Although I do like the IHs, Deeres, Allis's, etc, of the same era for nostalgic reasons, I do sometimes wonder why anyone would have chosen one of them over the Cockshutts. Cockshutt had a modern comfortable and sensible layout, a side-access operator position, modern independent PTO and great hydraulics, etc, while some other manufacturers were still making some tall, gangly tractors you crawled on from the rear, had you sitting like you were giving birth, geared PTO or hydraulics (or at best a dual stage clutch), goofy and knee-cracking shift patterns, no (or lousy) power steering, lower pressure and low-flow hydraulics, gauge and controls you had to practically use a broom handle to reach or have a pair of binoculars to see, etc.
But, getting back to your original question and if you are only looking at 70's tractors, I'd tend to agree with RRlund about those Deere's (though stay well away from the 1010 and 2010). But I'd also throw in some of the Ford thousand series as well.
The Massey Ferguson 135 with the Perkins diesel is hard to beat. The industrial version; the 202, 2135 and the MF 40 are great little tractors,
Thoughts - Thanks!
We may as well also ask which is the best beer , best scotch , best engine oil and best political party while we are choosing the best gas utility tractor .
Deere 1020, 1520 or 2020. NOPE! Would stick to Oliver 550!
Super 55 and 550 were top of the line in the 50s, but by 1960, the Oliver execs wanted to replace them with something with a diff lock and better hydraulics. They didn't want to tool up to build one though. That was why they made the deal to sell David Brown tractors as Olivers. The actual ag 550 was eliminated in 1967. They were designated as a White 2-44 then and sales were turned over to the construction division. A dealer could get a 550 through 1975, but they had to order it through the construction division and pay extra to have it painted and decaled as an Oliver 550. The ag division was selling the Fiat built utilities. If you're talking 1950s technology, yes, the 550 was the best, but he asked about the 70s and the 550 was 1954 technology, originating with the Super 55, pretty much unchanged.
I thought deere had a few three and four cylinder gas utility tractors in the 30 series ?
Always the Massey lineup
White 2-44. But the loader and hay work requirement has me thinking that an actual row crop 1555 or 1655 would be amazing. Otherwise everything else I think of is diesel.
*Oliver guy too.
Thoughts - Thanks!
If you already like M-F I would start by looking at those, and try to learn what to watch out for on those tractors ( common wear points and breakdowns, what repairs are NLA - No Longer Available. I like Deere but know the hydraulic systems on their utility tractors are more troublesome than their row crop cousins.
Condition of the individual tractor, your familiarity with a brand, and dealer support are big considerations. Any gas tractor will now be over 50 years old now, its use and maintenance can vary a lot, even the very best tractor could be turned into absolute junk over that length of time. You might look for a privately sold tractor in good field ready condition that was used occasionally on an acreage and avoid any used daily in a feedlot or a dairy operation or dumped off at a consignment auction.
Except for Ford and Massey-Ferguson most tractor companies only started making ag utility tractors as an offshoot of their construction equipment division around 1960, the big volume was in row crop tractors.
May I ask why you want to limit your search to gas utility tractors if you already have another diesel tractor, several row crop tractors and several other gas tractors?
Can’t go wrong with 574 or 674 gas, the C200 engine is very very dependable. If thinking about a loader look for a tractor with the straight front axle,a lot of them had swept back axles for shorter turning radius. About 6 inches difference
Thoughts - Thanks!
I don't know why you're limiting yourself to the 1970s. The 1960s had some outstanding gas powered tractors and they are still out there. I can't think of a bad make of tractor that was widely sold and used in the USA. You mentioned "raking hay" which would quite naturally imply that you also cut that hay and then what do you do after cutting and raking that hay ? Bale it? Pulling a baler and probably a wagon behind? Do you have hills? Takes adequate power and weight. Otherwise, you could be a casualty of your own doing. Maybe you already knew that. Now you do. Oh, I could come up with so many tractors of the 1960s that would fit your bill. And, They're still being sold and plenty of parts available. Your mention of maybe light loader work is a horse of a different color. Are you going to be able to find a tractor of the 1960s or 1970s with a loader on it that hasn't had the snot beat out of it loading manure or rocks? Good luck. So, you find the tractor of your dreams but it has no loader. Where are you going to find one? Beats me. I would advise against settling for an Industrial model. They're all worn out. But then, almost all of those are diesels. Good luck.
