CAV Injection Pump Governor Setting.
I have a 2675 (354 naturally asperated) with the CAV injection pump. It is a fairly new to me tractor that was purchased with engine problems (using a lot of oil and smoking). We did a full rebuild of the engine (and resealed the power shift and did the clutch for good measure). It is working fine with one issue, which is the governor does not seem to be working. It pulls down a lot when stressed, even a little, and then revs up high if you give the throttle a push.
We did no fuel injection work yet.
Before I take the injection pump cover off, my question is: could I change the governor reaction by just moving the spring position? I have resealed lots of CAV pumps but just always put the spring back where it was.
Thanks,
JP.
Thanks,
JP.
