D17 plunger pump GPM rating needed
A freshened up pump is 4 to 4.5 GPM and why do you need to know??? Pump pressure is 3,000 to 3700 psi max.
Thank you for your reply.
I have a valve that i purchased 30 years ago to add additional spools to the tractor. The valve i have is rated at 5-7 GPM it is also rated at 3500 psi.
My old pump puts out 3200 psi on a good day.
Sounds like you are in business !!! I always worry about those valve bodies that are only rated for 2500 psi.......
