clutch for Oliver 88
tom upton
What are you fellows running for a clutch in your Oliver pullers? I managed to get a 12 inch pressure plate and a 4 button disc from a 1655 in the 88 bell housing by grinding a tad inside the housing. However it was all in vain as one pull and it slipped quite badly. I am finding that automotive clutches dont have clearance for the throw out bearing tube inside the fingers. Is there a specific automotive PP that has enough clearance for throw out bearing tube or do I need to get a custom clutch made somewhere? Any suggestions appreciated.
Not joking it’s all brand new stock components. I used what I had before upgrading to try it. And it’s working so far. Unless it’s something I’m not familiar with I’m no clutch expert.
Thats pretty incredible. Like I said I put a new 12 inch stock clutch for 1655 in mine and it slipped badly for the first 150 feet or so, then seemed to take hold, but upon taking it apart it made a mess of the 4 button disc pads. I was only in 4500 pound class. I was running 5th gear though. I ended up ordering a 3200 pound pressure plate for mine that I hope will do the trick.
Cluth Dynamics in Ionia Michigan made a double clutch for 88s when they were in Lansing. They've since been sold and moved to Ionia (Lake Odessa). I don't know if the new owner still makes them or not.
