Front loader on a 3010
My 3010 1960 model has 2 extra hydraulic levers and 4 plug mins. I am building a front loader based on the 46A JD loader. Can those 2 levers be used to control the loader?
Yes but Fel will operate faster/better if an independent hyd valve designed for closed-center hyd system is utilized returning oil directly to tractor rockshaft return oil galley or ported hyd filter housing. 2nd photo is where to attach control valve pressure oil. Every time 3010 traction clutch pedal is depressed trans pump ceases to pump trans oil.
