2wheelgnnr
OK I think I screwed up my carb settings to the point where she wont start or stay running...starts up but cant sustain so dies. Is there a starting or stock settings to start from in tuning the carb. LIke .... screw all the way in and back off 2 1/2 turns to start... adjust from there.
WHen The new carb came a couple years ago it was at a setting that she started right up and I adj from there....but recently I did some adjusting as I thought I had a gas flow issue but I dont think I do but now I got it screwed up to where it wont stay running? I am NOT good at Carbs and I know it so I usually stay away from them. I was once told from a m/c mechanic that 99% of problems are the carburator...the other 1% is the carburator...
Thanks for any advise to get to a starting point maybe where I can go from there or get her going?? Got projects this spring I need to do.........
TIA
TIA
